Chain adjustment questions
Old Jul 31, 2007 | 03:08 AM
gerrynolan's Avatar
Default Chain adjustment questions
Greetings,
When adjusting chain slack on the KLX, is it common to require aligning the rear wheel? It seems like as long as you click each side of the adjuster evenly, it should remain "true" Also, does the torque of the axle nut apply pressure to the bearings? I torqued mine by feel and I need to ride it about 3 miles to borrow a torque wrench to set it at 80Lbs. I've been wrenching for 25 years so I'm pretty sure I got it reeal close to 80 Lbs, just don't want to hurt anything on the short ride to the torque wrench.
Old Aug 7, 2007 | 06:17 PM
JB1's Avatar
JB1
Default RE: Chain adjustment questions
As long as you get the adjusters on the same notch it will be fine. If your tightened by feel that should be good for3 miles or more
Old Aug 7, 2007 | 08:00 PM
TypeSH's Avatar
If you have been wrenching for 25 years why don't you have a torque wrench????[:'(]
Old Aug 7, 2007 | 09:33 PM
gerrynolan's Avatar
ORIGINAL: TypeSH
Sold all my tools & Boxes when I changed careers and moved from PA to NC. I could kick myself for selling the torque wrenches though. Grrrrrr.[:@] LOL What a Piece-O-Crap they use as a loaner at Autozone but at least it worked.
Old Aug 8, 2007 | 12:19 AM
kgwld1's Avatar
Come on slow up on the basses and buy some tools............! J/k
Kevin
Old Aug 8, 2007 | 01:02 AM
gerrynolan's Avatar
[sm=violin.gif]
[IMG]local://upfiles/5906/283ED454891D4B6F9151D361E1417F96.jpg[/IMG] I couldn't function without my Fender Power Jazz Bass.............
Old Aug 8, 2007 | 01:16 AM
gerrynolan's Avatar
.................Or My Marshall Stack
[IMG]local://upfiles/5906/360FB611B7FA4C9E8F4B94FE34596630.jpg[/IMG]
Old Aug 8, 2007 | 02:12 AM
mole's Avatar
80 lbs toruqe on the axle nut...Uh OH..
I used a big *** cresent wrench on mine, and I own a toruqe wrench.....Damm! I like the "feels good method"
Old Aug 8, 2007 | 02:16 AM
kgwld1's Avatar
I have a Big Apple Strat and Randle 1/2 stack no pics I'll have to take some. My practice amp line 6
Old Aug 8, 2007 | 08:31 AM
MaverickAus's Avatar
ORIGINAL: JB1
That is NOT always the case, of course most of the time it will be right but not always. The adjusters can be out so it does pay to check the "straightness" along the chain at least until you know for sure the adjusters are correct.
If you are experianced I'm sure you have a fair idea of torque .... if you use the same spanner each time. I bought2 torque wrenchs cause I will one day put my 300 kit on and I have already broken the front axle studs going over the correct torque.
Cheers
