CHAIN
Old Mar 6, 2007 | 03:47 AM
kawiridr04's Avatar
Default CHAIN
wat size chain should i use if i get a 47 tooth sprocket and go with the 14/47 setup. i know i need a 520 but wat size exactly? 520x102,4,6,8 etc? or 520x84,6,8,90 etc?wat size chain did u all get. i'm lookin at rocky mountain atv/mc
Old Mar 6, 2007 | 04:16 AM
Default RE: CHAIN
I'm running a 110 chain with a 14/49 combo and it is fairly tight..... only one notch on the tension......best of luck picking the right size.
Old Mar 6, 2007 | 04:19 AM
kawiridr04's Avatar
Default RE: CHAIN
i think a 108 oughta work with 14/47 setup. wow. u gotta 49 tooth. how is the difference from stock. how does it run
Old Mar 6, 2007 | 04:25 AM
Snal's Avatar
Default RE: CHAIN
Pardon my stupidity, but what are you guys getting from these sprocket changes exactly? I've read that 1st gear is quite low on these bikes already, are the gains coming in 2nd and 3rd and 4th gear pulls on the trail? I'm a Land Speed Racer...usually working on the other end of the gearing. Hope to be picking my bike up tomorrow, and I'm making my list of parts to grab while I'm there.
Old Mar 6, 2007 | 04:28 AM
kawiridr04's Avatar
Default RE: CHAIN
well i just want more pull 4 the trails and torque. the klx is kinda lackin in low end torque so im lookin 4 a little more. ive gotta pipe and i think this will give me wat im lookin 4
Old Mar 6, 2007 | 06:44 AM
EvildoerZX10R's Avatar
Default RE: CHAIN
ORIGINAL: Snal
Well, first gear is not really that low and 6th gear is overdrive. The little engine can't hold speed in 6th with the stock gearing. Top speed is actually increased when you drop one in the front or go up three in the rear. If you do both you it runs a little high in the RPM range on the highway but still runs great and you get a lot more bottom end grunt. I often ride with my family and itwas really hard going slow with the stock gearing.
Old Mar 6, 2007 | 06:49 AM
Default RE: CHAIN
ORIGINAL: EvildoerZX10R
ORIGINAL: Snal
Larry, looks like you guy have a blast on those bikes, I have always wanted to do that but never really looked into it. Where do you test your bikes?
Old Mar 6, 2007 | 07:44 AM
Snal's Avatar
Default RE: CHAIN
The only place we can test is the track...although we have been known to do late night bursts on unknown backroads <G>. We do have dyno access to test our mods. It IS alot of fun! We're not that fast, compared to alot of other vehicles, but we are more inclined to have fun, but we are quitegood in our class.LSR has been my 2nd or 3rd childhood, we're currently building a hybrid using a 1986 GSXR 750 frame that I've modified to accept an Ironhead Sportster engine. I stretched the frame 12" and we're desperately trying to get ready for the March race.
Maxton is great! Anybody can walk right up to a pit area and shoot the bull with any team, ya might not be welcome if they just blew a 20k engine, but other than that everybody is quite friendly.
It's getting more difficult now....but we used to do 15-20 passes down the track per day....it's getting more popular now, and the staging lines get longer, but it's still alot of fun.
Old Mar 7, 2007 | 02:06 AM
kawiridr04's Avatar
Default RE: CHAIN
ok, will someone please tell me if the 520x108 chain will work eith a 14/47 setup
Old Mar 7, 2007 | 03:44 AM
lcpl0331's Avatar
Default RE: CHAIN
no
