Carb problem driving me insane
Take some brake clean or carb cleaner and spray it around the boot area with it running. If you have an air leak it will start to run different when it sucks it in.
I usually do this everytime I have the carb off.
How do your cables run. I know it's really tight where they go under the tank and fit to the carb'. Are they free at full lock left, full lock right. I know they have to be just so or they'll bind. Could be the problem.
You might try checking to make sure the bell crank (the part the cables are attached to) is moving freely and returning properly. Also pull the carb off and look to see if the butterfly valve is closing properly. Good luck.
