can't set the clock
Old Apr 10, 2013 | 12:45 PM
Kaw-Liga's Avatar
Default can't set the clock
I have an 09. After the time change I tried to set the clock. Holding the rest button for more than 2 seconds does nothing but reset the odometer.
Old Apr 10, 2013 | 01:19 PM
What clock? LOL. I have on '06, no clock.
Old Apr 10, 2013 | 02:03 PM
Lotrat's Avatar
The MODE button is on the left.
The RESET button is on the right.
Clock:
To adjust hours and minutes:
• Turn the ignition key to “ON”.
• Push the RESET button for more than two seconds. Both the hour and minute displays start flashing.
• Push the RESET button. The hour display only flashes. Push the MODE button to advance the hours.
• Push the RESET button. The hour display stops flashing and the minute display starts flashing. Push the MODE button to advance the minutes
• Push the RESET button. Both the hour and minute displays start flashing again.
• Push the MODE button. The displays stop flashing and the clock starts working.
NOTE
○Pushing the MODE button momentarily advances the hour or minute step by step. Pushing and holding the button advances the hour or minute continuously.
○The clock works normally from the back-up power while the ignition switch is turned off.
○When the battery is disconnected, the clock resets to 1:00 and starts working again when the battery is connected.
Old Apr 10, 2013 | 02:51 PM
Kaw-Liga's Avatar
Thanks for trying to help. I have my owners manual and already read the clock setting instructions you posted. But when I press and hold the reset button the clock digits do not flash. Apparently it is broken.
Old Apr 10, 2013 | 06:06 PM
jeffzx9's Avatar
If you must have a clock.....you can always buy a cheap-o solar G-Shock watch, take off the straps, and either Velcro or use 2x auto trim tape for sticking on your top triple. Works just fine.
Old Apr 10, 2013 | 06:37 PM
ol'klx-er's Avatar
Try disconnecting the battery just before 1, then reconnect it right at 1.
Old Apr 10, 2013 | 06:57 PM
Kaw-Liga's Avatar
Actually, I already have a cheap-o combination thermometer and clock velcroed to my fuel tank. I leave the display on thermometer as that is what I bought it for, not the clock.Thanks for reminding me, I just went out and reset THAT clock.
But the cockpit display clock is staring me in the face and it's an hour off and aggravating me.
Old Apr 10, 2013 | 06:59 PM
Kaw-Liga's Avatar
You're a genius. Thanks!
Old Apr 11, 2013 | 01:41 AM
Sharan's Avatar
From memory, you gonna have the trip meter set to show your total mileage and not a trip A or B. If in trip A or B mode, the clock cannot be adjusted.
Cheers.
Old Apr 11, 2013 | 03:52 AM
Kaw-Liga's Avatar
Cheers.
Sharan has submitted the correct answer and is the winner of the 64 thousand dollar prize to be awarded by Kawasaki! I tried this and it worked. I feel stupid for not figuring this out myself.
