cams
Old Feb 15, 2010 | 02:05 PM
GaryC's Avatar
Default cams
Are there any cams available for the 250 that will enhance the 351 kit?
Does the KX use the same head design?
Old Feb 16, 2010 | 05:24 AM
ddt1972's Avatar
There are a few out there. Over here in Japan, we use a Nassert cam, it is a higher lift and longer duration than stock, cost is around $400 for the pair. You can even press the KACR into the exhaust cam. I am not sure about the KX head though. I think web also makes one, but it may be a regrind of your stock cam, not sure.
Old Feb 16, 2010 | 05:38 AM
MaverickAus's Avatar
No...
Old Feb 16, 2010 | 09:29 PM
2k1w=no$'s Avatar
Web cams from the US, Jerry from four stroke works might be doing cams, and you can get Yoshimura USA to get D-tracker cams from Japan for you(you'll have to get one of the members from Japan to get you the part numbers)
Old Feb 17, 2010 | 12:31 AM
ddt1972's Avatar
The yoshimura and the nassert are the options from Japan. I may have a set of the Nassert cams available, pending another interested party's reply.
Nassert sale page, the whole kit costs about $1000, and gives you cams, a 315cc kit, and external oil cooler:
http://www.naps-jp.com/php/y-004.php?id=0000134486
Yoshimura cams page, with part number:
http://yoshimura-shop.netmove.co.jp/..._cams3_e&d=300
speedracer138
Aug 13, 2007 05:49 PM
biglg7
Apr 6, 2007 07:56 AM
greenkow
KLR250
Mar 28, 2007 02:26 AM
636_80
Jan 6, 2007 08:24 AM
vic
Jul 11, 2006 11:49 PM
