cam position
Old Sep 6, 2006 | 11:51 PM
Default cam position
hey guys i need some help, my motor was making some noise, and i dont trust the dealer so i decided to check my valves myself. When i make sure the mark is on t.d.c. the cam lobes all are pointing towards the spark plug, from other pics it looks like they should be pointing away from the spark plug... wtf.. little help... first time doing this.... i cant get a measurement on them with the lobes pointing towards the spark plug... any input?
Old Sep 6, 2006 | 11:56 PM
Default RE: cam position
Should look like this at TDC:
What does yours look like?
Old Sep 6, 2006 | 11:58 PM
my lobes are pointing towards the spark plug, yours are pointed away from the spark plug.... so my t.d.c mark isnt right?
Old Sep 7, 2006 | 12:04 AM
It's not necessarily wrong. Use this procedure to find TDC. Turn the crankshaft rotation bolt counter clockwise while watching the inlet valves - valves closest to the rear of the bike. When the valves have just finished opening and closing (moving downward adn returning upwards), turn the crankshaft continuing in the same direction about 1/2 turn until the "T" mark is lined up in the notch. The camshaft marks should then line up with the top of the cylinder head and the piston should be at TDC.
Old Sep 7, 2006 | 12:09 AM
thats what i was doing... is there more than one T mark on that piece?
Old Sep 7, 2006 | 12:13 AM
Are your lobes correct now? I think the critical thing is that you go about 1/2 turn ccw _after_ you see the inlet valves open and then close. If I'm not mistaken, and I could very well be since I just loaded up on pain meds, a 4-stroke engine hits TDC twice during the firing cycle. You probably have it at TDC during the other portion of the cycle.
Old Sep 7, 2006 | 12:14 AM
ok... ill go try to see if i can get it there again... dont be greedy share some of those happy pills....
Old Sep 7, 2006 | 12:17 AM
LordVngr's Avatar
Your valves are probably 180 degrees out. I can remember on my dr250 when doing the valve adjustment that the valves would be at TDC Or 180 degrees out. IE - exactly opposite from what they should be.
LV
Old Sep 7, 2006 | 12:18 AM
ah!!!!! so there is 2 t.d.c.'s thats kinda what i figured... ok got it now....another question, if the distance is greater than it should be, does that mean a bigger shim?
LordVngr's Avatar
ORIGINAL: EMS_0525
I'd settle for A bIG FATTY
LV
