Cam bolt specs
Old Dec 17, 2019 | 10:01 PM
Rickybobby2's Avatar
Default Camshaft torque specs
I am about to go ahead and MCM my 2018 KLX 250. So before I start I was wondering if anyone one could kindly provide me the torque specs for the " cam housing" bolts as well as the cam sprockets bolts. Thanks
Old Dec 17, 2019 | 11:06 PM
You want both the spec and the tightening sequence as well. Look around with a couple searches, you will find the KLX250 factory service manual. About any of them will do for that torque spec if you can't find one for the 2018. They are basically the same engine over all the years from 1994 to date.
Old Dec 17, 2019 | 11:16 PM
Does this look right?
Old Dec 17, 2019 | 11:18 PM
The sequence is stamped on the bracket, I found 87 inch pounds. I may just remove the spring rather than the whole ACR.
Old Dec 18, 2019 | 05:59 AM
Mateja's Avatar
I would say that the intake cam is one tooth higher than it should be.
Or does it seem assymetric only to me?
Let’s wait for other responses.
This is how my cams look like:
Old Dec 18, 2019 | 11:45 AM
That, intake one tooth too far counterclockwise. Should mirror exhaust.
Old Dec 18, 2019 | 01:01 PM
durielk's Avatar
One guy posted the torques over in my 'sheared cam bolts' thread in stead of this one, by mistake I think. good luck
Old Dec 18, 2019 | 03:22 PM
Check cam alignment one final time after installing the cam chain tensioner, caps, etc.
Also see post 72 in my 351 thread linked below for my pic of cam positions.
Old Dec 18, 2019 | 03:55 PM
I started it up and let it run for a few minutes. I just removed the spring on the ARC. There was no issues staring. This weekend I am going to pull the valve cover off and recheck everything. Better to be certain that to assume everything is fine. I will post a pic before I through it all back together and see what everyone thinks. Thanks to all.
Old Dec 18, 2019 | 11:37 PM
I found a PDF manual. Here are the torque specs incase anyone needs them
