Broken headlamp
Came back from a ride today with a broken headlamp :eek: The OEM retails at $109 on sites I've checked :eek::eek:.
Anybody knows a better/cheaper alternative? |
Not exactly cheaper Racelight, M/C Single 8 Inch Halogen but its got to be better than the stock flashlight :D
If you change for something else I could be interested to buy the plastic that goes around the stock headlight. That would lower your cost to change!
I saw some people changing to the trailtech x2, never tried myself.
Trail Tech || X2 Motorcycle Headlight https://www.kawasakiforums.com/forum...on-06-a-36619/ |
Thanks for the suggestions. The X2 looks interesting, will consider.
Ray,
I have the TrailTech X2 and vapor computer. The X2 fits SO TIGHT that I'm not sure it can be done on an '06/'07 model while keeping the stock gage cluster. Someone please chime in if I'm wrong. I think Dan888 knows. You could also look at other lights that members have tried while keeping the gage cluster. I am impressed with the X2 light output. It would be tough for me to go back to stock. Have you checked ebay for a used part? I'll likely never install my stock headlight and may as well offer it up for sale. I sold the gage cluster a while ago to another member who busted his up. Everything else is there. Brackets, lamp, plastic, etc. I also have a spare X2 with the lower bulb intermittently working. Could be bad bulb or a wiring issue; I don't know. I could be interested in offering this up. |
Originally Posted by IDRIDR
(Post 515777)
Ray,
I have the TrailTech X2 and vapor computer. The X2 fits SO TIGHT that I'm not sure it can be done on an '06/'07 model while keeping the stock gage cluster... . Still, your oem headlight is tempting... There is one on eBay, thanks for the suggestion. I'll pm you shortly. Ray |
Originally Posted by doum
(Post 515768)
Just realized your interest while revising the posts... At this point I am not going to change, trying to get an oem unit. If I go another route and the plastic is available, I'll let you know! |
Originally Posted by RayCour
(Post 515784)
Doum,
