Break in period 2009 KLX-205S
Old May 1, 2009 | 04:46 PM
karlcchen's Avatar
Thank you for bike check list, I already found chain is too tight from dealer.
I am going to Utah, Moab. It's long way from home if something happened.
Karl
Originally Posted by lcpl0331
You should take some time to check out that all the screws, bolts and cables are still tight before you head out. These bikes have been known to have loose bolts and whatnot. Also you might consider lubing up your shock linkage and swingarm bearings. The factory isn't exactly liberal with the grease. It's real easy to do and takes about 45 minutes or so. The linkage bolts tourque is 60 ft .lbs and the swingarm bolt tourque is 70 ft.lbs. The rear axle bolt I torque to 70 ft.lbs. I forget the exact torque so I just go with 70.
Old May 1, 2009 | 10:40 PM
Randy49's Avatar
81 foot lbs. for the rear axle bolt.
Good luck on your trip and don't forget a cell phone besides other needed items.
Old May 2, 2009 | 12:48 AM
SlapDrum's Avatar
Let it warm up, very the rpm thruogh the gears for the first 40 miles.
then ride it like you stole it
karlcchen
Aug 12, 2011 03:36 PM
2dardi
Ninja 250R
31
Oct 4, 2009 03:58 AM
ale
May 7, 2006 11:19 PM
barbar
Apr 11, 2006 08:43 PM
LKNY
Mar 31, 2006 04:13 AM
