Brake/Clutch levers: OEM vs CNC Pivot style & Shorty
Old May 14, 2016 | 09:50 AM
klx-vn's Avatar
Default Brake/Clutch levers: OEM vs CNC Pivot style & Shorty
Just trashed my oem clutch lever and while googling for a replacement numerous references to "cnc pivot" and "shorty" style links come up. The oem lever worked fine and the replacement part is pretty cheap but any good reason to go with something else?
Old May 14, 2016 | 12:05 PM
Werloc's Avatar
If you have a hard pulling clutch like I "did", think about the Moose Racing EZ3 clutch perch/lever assembly. I now have a VERY Easy 1 finger pull clutch. Wow, what a huge difference. Very happy with it. BTW, get yourself some handguards and you won't break levers anymore. Get ones with the bar, not just the plastic covers.
Old May 14, 2016 | 03:02 PM
Got the money to spare, buy the big bucks levers, but I'd do some bark busters first then whatever levers you want. The cnc folding levers are great to save levers, but bark busters can save fingers and hands if you know what I mean.
Old May 14, 2016 | 03:37 PM
klx-vn's Avatar
Will check out aftermarket lever options. Already have Acerbis brush guards... Not 100% effective apparently.
Old May 14, 2016 | 03:55 PM
These are pretty near 100% effective:
The Rally Pro X-Strong is a durable injection-molded nylon composite handguard that features an anodized aluminum bar for ultimate protection. It includes an indexed steel bar-end insert that mounts solidly and will not allow the guard to rotate in a crash.
Tough stuff there. The internal aluminum guard is the bomb!
Old May 15, 2016 | 01:53 AM
durielk's Avatar
Don't bet the farm on that!
Old May 15, 2016 | 02:43 AM
SteveP's Avatar
When my levers bent i took them off, cut them down, and grinded/sanded them smooth. My brake lever was bent so badly it looked like a candy cane, but when I cut it down and smoothed out the end, it looked like a shorty lever that i would have otherwise paid for.
Old May 15, 2016 | 03:48 AM
klx-vn's Avatar
Those are what I have... and I even got the Kawasaki green/black ones to match my bike. They'll rotate given certian impacts.
Old May 15, 2016 | 11:00 AM
Well, as I said, near 100%. I will say I run my levers near horizontal to the ground, they won't fit behind the guards unless I cut them down, which I did. Two finger clutch, three finger brake.
I actually did tip hard enough on the 650 that it actually bent the end in slightly at the end, kind of a slight small S bend at the end, bars didn't bend. Never got the levers yet, but then again maybe I don't crash hard enough...
Old May 15, 2016 | 11:57 AM
klx-vn's Avatar
After seeing a video (ktm adam riemann i think) about the benefits of feathering the clutch as opposed to modulating the throttle in offroad riding I think this setup makes a lot of sense. $38+shipping does't sound too crazy... Am I looking at the right part?
Moose Racing - EZ3 Lever Assembly: BTO SPORTS
