Blue-ing Header Pipe
Old Sep 26, 2006 | 02:52 PM
cwgoff's Avatar
Default Blue-ing Header Pipe
Alright folks, I need some diagnostic help.
I have noticed that my Muzzy header has started to blue a little bit in kind of an irregular pattern. The discoloration is mostly between the exhaust port and the heat shield, but a little bit extends under the heat shield.
I don't care about the aesthetics of it, but want to make sure that I respond to whatever condition might be causing the blue-ing. I know that pics will help, and I will get some up tonight, but as a first pass would it be a safe assumption that I am running to lean and therefore my exhaust gases are too hot? I am combining bits and pieces of info that I have gleaned from other threads, so I might be way off on this assumption.
Note my setup in my signature below.
Any thoughts?
Old Sep 26, 2006 | 04:40 PM
Marty's Avatar
Default RE: Blue-ing Header Pipe
I don't see where you have opened up the pilot screw to 2 to 2 1/8 turns yet. Has that been done?
Old Sep 26, 2006 | 05:32 PM
cwgoff's Avatar
Marty, yes I am out 2.5 from bottom. I need to update my sig.
Thanks,
Chris
SKOOTR
Jan 5, 2008 09:41 PM
ben_cline
Ninja 250R
17
Aug 29, 2007 04:40 AM
Aug 20, 2007 05:56 AM
Tom Whitfield
Jun 29, 2007 03:28 PM
