basics?
Thank you a16tony! I went and read the faq, but can you tell me if i change the exhaust system do i have to change something else or the bike will run good with only the pipe changed (sorry for my bad english, my questions may be not too clear...)
If you get an aftermarket pipe you will have to at the very least get a larger main jet, 125 size minimum. The general consensus is to get a 125 or 128 main jet, 40 pilot jet, N1TC needle, clip, collar and the pipe of your choice. If you don't want to mess with sourcing the individual parts a Dynojet kit for the KLX300 has all the parts required minus the pilot jet (which is debateable at this point as well, some change it some dont). The Dynojet kit also comes with a selection of main jets so you can fine tune the carb. to your liking and altitude.
Thank you bryanjt. I got another question. Do we still have to run the bike at low rpm when it's new, if so what rpm and how long? Does it make a difference somewhere if i don't do it?
