Bashplate from Utahcycle
Old Dec 14, 2009 | 06:01 PM
Oldtimer36's Avatar
Default Bashplate from Utahcycle
After doing a search to determine which bashplate I wanted I ordered from Utah Cycles and put in the 15% discount code of 852147. The promotion had expired so I called them and they now have a 10% discount 45789. BTW, thanks again for responding to my Relay post. A new battery properly charged solved the problem as many of you suggested it would. There is a wealth of info on this board.
Old Dec 14, 2009 | 11:13 PM
Good bashplate but the hardware will corrode and seize .... especially the allen type bolts.
Use a LOT marine axle grease on those suckers....that should help.
Old Dec 14, 2009 | 11:22 PM
Maybe just switch that hardware out with some stainless steel nuts bolts etc
Old Dec 14, 2009 | 11:31 PM
Actually Dan's idea is better than my axle grease recommendation
Old Dec 14, 2009 | 11:42 PM
Oldtimer36's Avatar
Thanks, I'll do that. It's a lot easier to do it right from the start then to struggle with it later.
Old Dec 15, 2009 | 01:54 AM
WestOzKLX's Avatar
If you're using stainless hardware then get some copper grease or you'll have the same problems os corrosion only the stainless 'fires up.'
Old Dec 15, 2009 | 02:39 AM
ol guy's Avatar
Loctite nickel anti seize works good or even a little liquid Teflon on the threads. I had my Utah plate off last week after a year with no problems.
Old Dec 15, 2009 | 02:19 PM
Oldtimer36's Avatar
Never heard of this stuff. Is it pretty common in auto parts stores?
Old Dec 15, 2009 | 10:06 PM
I have never had a prob with Stainless fasteners corroding or oxidizing (yet). I have however started using anti-seize compound on many of the fasteners I take on and off (mostly car parts) , so I would 2nd W-Oz's advice. I bought this to lube the threads on a new set of sparkplugs. Recomended for plugs going into aluminum heads.
I bought this at the local O'Reillys auto-parts store. Looks like it's pretty much what W-Oz put up.
$6 for the big jar $3 for a small tube.
Old Dec 16, 2009 | 07:09 PM
Oldtimer36's Avatar
Thanks, I stopped by O'Reillys today and picked up a can.
