Auxiliary lighting
Old Mar 27, 2014 | 02:05 PM
pghxd9's Avatar
Default Auxiliary lighting
What are you folks doing, if anything, for auxiliary lighting? I just installed a more powerful bulb in my stock headlight, but I would really like to add some driving lights.
Old Mar 27, 2014 | 02:10 PM
Nikolaj Lykke's Avatar
I've got a Phillips Nightbreaker bulb and its pretty nice. Much more powerful than the stock bulb. However, there are some new LED H4's out which supposedly are almost as powerful as Xenon lights. I think I will try them at some point, they are fairly cheap too.
As for even more lights, I am interested too. I've been considering a LED lightbar or something like that.
Old Mar 27, 2014 | 02:48 PM
pghxd9's Avatar
I put in a silverstar ultra, but haven't had it out on the road yet. I run them in my car and I like them. I had not seen LED h4s. As far as adding lights, LED seems like the way to go. I know good setups are hundreds of dollars (Baja Designs, etc), but that's not in my bike budget this year. I've seen some cheaper stuff on eBay, but it's so hard to know what you will get, which is why I brought up the topic. Stock lighting on our bike is way too weak for night riding inmy opinion.
Old Mar 28, 2014 | 12:42 PM
DYNOBOB's Avatar
My "homemade" led driving lights on the KLX
I see this guy is selling led headlight bulbs now: LED Headlight "Bulb" replacement Modules - ADVrider
On the Husky I went with these LR4: LEDRider - New Quad Cree XM-L LR4 Floods - ADVrider They draw 44watts but you'd be ok on a KLX if you weren't running heated gear. They are unbelievably bright.
Old Mar 28, 2014 | 04:16 PM
pghxd9's Avatar
Nice looking setup! Do you know the specs on those leds on your klx? Do you have any problems with power output with the stock stator?
Old Mar 28, 2014 | 04:37 PM
Arickrock's Avatar
I just ordered these lights.
Robot Check Robot Check
Hope to mount them very similar to DYNOBOBs set up.
Old Mar 28, 2014 | 06:48 PM
pghxd9's Avatar
Arickrock, those are pretty much what I've been considering after shopping around eBay and amazon.
Old Mar 28, 2014 | 07:18 PM
Arickrock's Avatar
Yea the might not be as bright as what DYNOBOB shows above but I think its a good place to start. Cant justify $150 plus in lights just yet. They should be in next week and I will be sure to post up some pictures of the finished product.
DYNOBOB - what thickness was the metal you used for your bracket?
Old Mar 29, 2014 | 01:16 PM
DYNOBOB's Avatar
The KLX has 9w led MR16 bulbs that I fit into some old lights I had around. No problem running them. You have ~85watts of extra power available on a KLX (while moving - less at idle).
The Amazon lights you're looking at are great lights for the money. They're not a long range light but are perfect for trail riding and will make you a lot more visible to approaching traffic.
Old Apr 1, 2014 | 12:56 AM
Arickrock's Avatar
Default How did I ever drive without these!!!!!!!!
Custom made some brackets similar but opposite to Dynobobs. I would say there is easily 3 times as much light as before. They are bright for one LED bulbs. I would highly recommend extra lighting to anyone that hasnt done it yet.
Stock light only
With new aux lighting
Stock head light(with some light provided by my exterior house lights)
With new lights
