Anybody else contstantly readjusting their A/F screw?
Old Nov 5, 2012 | 03:48 PM
That's not right at all. Something is wrong there. The Kouba screw is threaded just like the OEM unit unless you got a bad one. Your description of the Kouba screw not going in loose and having a little resistance is relatively normal. I wonder if the threads in the carb are buggered? Still, the brass fuel screw is usually the "victim" in a crossthread scenario rather than the carb body. Vibration shouldn't be a big issue here, since the carb is mounted between two rubber mounts.
The fuel screw just should not turn on its own. I'm curious about your need for a two steps larger pilot jet.
Old Nov 5, 2012 | 04:06 PM
LikesToThump's Avatar
Me too, with the FMF, K&N, a ground header, smog delete, removed snorkel and dyno jet kit with a 24 main, I'm at 2.5 turns out on the stock pilot... and I still get a good amount of decel pop with no throttle.
Old Nov 5, 2012 | 11:53 PM
FM_Thumper's Avatar
Are you sure your o-ring and spring are still in place on the screw?
Yeah make sure they are in the proper order: O-ring, washer, spring, then the Kouba screw.
Kouba states that it can and will vibrate out if turned farher than 2.5 turns out.
Old Nov 6, 2012 | 04:24 AM
djchan's Avatar
I can barely turn my Kouba screw by hand it's so tight.
tucaz#2
Mar 9, 2010 02:20 PM
DOG MAN
Ninja 650R
Jul 14, 2007 02:39 AM
Merdox
Mar 28, 2007 02:43 AM
2k1w=no$
Dec 10, 2006 09:35 PM
taystyl
May 10, 2006 09:09 PM
