any experience with trail tech vapor??
Old 04-04-2007, 04:18 PM
mikem1965's Avatar
Default any experience with trail tech vapor??
saw this on e-bay- looks interesting- has all the bells and whisles- speedo, tach, engine temp, clock etc.etc..just wondering if it is a cheap POS ora decent and durable add- on. anyone tried this??
http://cgi.ebay.com/Trail-Tech-Vapor...QQcmdZViewItem
Old 04-04-2007, 04:43 PM
mooredan's Avatar
Default RE: any experience with trail tech vapor??
Just do a search on "vapor" in this forum and you'll find plenty of posts:
https://www.kawasakiforums.com/searc...p;timefilter=0
Old 04-04-2007, 11:25 PM
Not sure, but I think it's cheaper direct from Trail Tech. They work well.
Old 04-05-2007, 02:46 AM
KAWASAKIspeed's Avatar
I have the model before the vapor and they just hold up to anything. they are great products. just wondering. Why do you need one you have a the stock one that is almost the same. iy you do get one do a write up of how everything went and how they do.
Old 04-05-2007, 05:34 AM
mikem1965's Avatar
the reason I am looking at them is; 90% of my riding is/will be at the track- I am trying to lose as much weight as possible without a diet- I plan to hook the vapor up and then be able to disco the headlight easily- this should lose at least 4-5 lbs. with headlight and big steel bracket gone- plus I like the thermostat, clock and stopwatch.. if Iget it 'ill write a report- still working on my complete mod report.. and praying that my wife doesn't see thevisa bill...
Old 04-05-2007, 08:47 AM
TeamKLX250's Avatar
Its all good, thats the same price from TrailTech Brian their prices have gone up
Old 05-02-2007, 04:33 AM
Mtns247's Avatar
Does that sync right up to the wire harness from the stock speedo and tach?
Old 05-02-2007, 11:01 AM
TeamKLX250's Avatar
ummm sorta ... lol
have a look at http://www.trailtech.net/media/instr...structions.pdf
Old 05-02-2007, 07:28 PM
mooredan's Avatar
The Vapor that I have installed has worked well for me. However, the ambient temperature sensor seems to be 10-15 degrees off (reading too warm). Anyone know how to calibrate this?
Old 05-02-2007, 07:51 PM
Shadetree's Avatar
Dan,
You may have to "Calibrate" the sensor a few feet away from the radiator...
Just a thought...
Quick Reply: any experience with trail tech vapor??
