ANSWERS TO THE GAS GRADE QUESTIONS
It's fun to argue about though!
It is true that a KLX will run under load on 87 octane without pinging depending on the brand. My KLR650 runs on it as well. However, I use premium fuel. Not to avoid ping, only to get a fuel with less impurities, my bike gets better gas mileage and just runs better with it. Gasoline companies generally start with a higher quality base fuel when they blend their high octane fuel. Probably more important for carburated bikes that burn less efficiently and leave more deposits behind anyway. Buying premium for a bike is inexpensive, too. When filling up my KLR 250, its only an extra .50 - .75 to go for the premium anyway. Cheap insurance against buildup of deposits.
Let's hear some come backs on this one.
ORIGINAL: FM_Thumper
Finally unless you go to a gas station that has individual hoses, regardless of what you pay for, you are getting a gallon and a half of whatever the guy before you bought(in most cases 87 octane). So in the case of the 1.9 gallon KLX tank.....well you can do the math.
I didn't start this thread to rehash old arguements. There is a lot of crap out there on the net, and since I have a good friend who has worked 6 yrs in the refinery business and has no reason to lie to me, I figured people would like to hear it right from the horses mouth. Getting the same gas the the guy before you bought is a simply not true.
ORIGINAL: deej
Thanks for the interesting information, so we should run the highest grade? Will it run better and be better for the engine? (sorry for using better twice in one sentence.)
My Thesaurus didn't have another choice.
In this hot weather the higher octane is more likely to deterengine knock isn't it? Especially if your lugging the bike around .
ORIGINAL: fireroad
Sorry, FM-Thumper, your math is way off. Like I stated in the original post, the state and feds take regular samples from gas stations to ensure that the consumer is getting the correct minimum octane.These samples are 1 qt size, or 1/8 the capacity of our tanks. That samplehas to meet the minimum octane requirement or the gas station and the refinery get fined.In order to meet those requirements 1. the hoses have a drain system and 2. the refineries sell gas that is slightly higher in octane then the minimum. Look on the pump and you will see the inspection sticker (say something like dept of weights and measures).
I am no expertbut I did manage a gasstation a long time ago and I don't remember the inner diameter being as small as you state.
Also please don't take it personally but just because someone is inan industry for 6 years does not mean that they are an expert and the final word. I have been in the automotive business for 20 years and ther are plenty of higher up executives that have been in it longer and know nothing aboutcars.
Quite frankly, Iwould like to know the real truth about this myself. I do know thatmy R1150R knows that there are leftover87 octane in those hoses. My R1150 pings like crazy unless I put 93 octane in it. If I go to a one hose station, it always pings.
