Another Newbie Question
Old May 31, 2013 | 02:55 PM
Originally Posted by zl PINHEAD lz
It is..
Well, that changes everything as far as the jetting discussion goes...LOL!
Old May 31, 2013 | 03:25 PM
cmott426's Avatar
Yeah that is what I was getting at. You have no jets to "Rejet". Programmer is what you need. but you should be fine with out it. The Computer will compinsate for it....to a point.
Old May 31, 2013 | 03:46 PM
zl PINHEAD lz's Avatar
So that brings me on to my next issue LOL
what are the options for riding with the FMF pipe that hasn't got a o2 sensor bung?.
ive read a few forums that say drill a hole in the pipe, weld on a new bung and do it that way. but thought id ask on here if any one else has had any similar experiences?
Old May 31, 2013 | 08:40 PM
darkmarc's Avatar
narrow band sensor helps adjust ecu with lambda feedback. I'm unsure how it would run without it. It should be easy to add 02 bung at exhaust shop anywhere. mount sensor from side not bottom for moisture issues. good luck
marc
Old May 31, 2013 | 10:03 PM
marc
Thought that would be the way around it, ill keep you all updated.
Thanks
Old Jun 20, 2013 | 07:04 AM
So I've finally fitted the fmf powercore 4 pipe, I had bought the m18 x 1.5 O2 sensor bung which turned out far too big for the O2 sensor.
However bolted up the new pipe without the sensor installed, as a tempory measure that has been tie rapped to the pillion foot peg.
After a couple of days I have not had any warning lights etc and bike seems to run as it should.
Although I do have one concern, this exhaust is LOUD!! Is anyone running the quiet core insert in theirs and did it reduce the sound much?
Thanks guys
Old Jun 20, 2013 | 10:41 PM
darkmarc's Avatar
Good to hear it's running good without the o2 sensor. I can't believe your tag is so big. It looks like a lunch tray.
marc
Old Jun 21, 2013 | 01:33 PM
  #28
marc
Thanks
Yeah Standard size here in the uk, I definitely could do with going down a few sizes.
ex5seeker
Ninja 500R
Mar 15, 2007 10:48 AM
Snal
Mar 4, 2007 08:53 AM
dudley337
Nov 23, 2005 03:02 PM
NinjaBoy
Sep 7, 2005 04:58 PM
firedog
Jul 28, 2005 08:47 PM
