Acerbis 3.7 gallon tank all fuel mod question
Old Jan 25, 2013 | 10:17 PM
Ranger Ron's Avatar
Originally Posted by RobG
Almost... there's no way to connect the line to the petcock that I know of.
snip/snip
But yeah once that's done, I think the vacuum from the engine would be enough to suck the fuel up from there.
Rob
The screen filter in the tank screws into the petcock. The petcock thread is common 1/8" FPT.
For my conversion I used a 1/8" MPT hose barb at the petcock. There were two pieces of end weighted flexible tubing that led to the bottom of the wings. These were TEE'd into the 1/8" barb in the petcock.
When you say vacuum from the engine, I'm guessing you mean suction on the fuel line from the carburetor?? If so, that won't work because there isn't any. Remember the float bowl is vented to atmosphere.
I used a snowmobile fuel pump. You can see it on the inside of the frame behind the side cowl. It's bolted to the oem petcock bracket.
Ron
Old Jan 25, 2013 | 10:49 PM
RimBender's Avatar
have the acerbes and the smaller clark. pro's and cons. I like the radiator protection of the 3.7 but don't like the way it carrys more weight forward (than the already forward weight biased bike) make the front end push in loose stuff. It is worth it for long rides for the added fuel. Only way you'd not get most the fuel out of the wings is if you were on long straight up slab. If your offroad hitting bumps and leaning the bike you'll get most of it. If you do cough I find pointing the bike up a bank or hill is easier than stopping to tip. The section of the tank the petcock draws from is sort of a well, and will catch the sloshing fuel. The 1 time I ran dry there was about a fist size amount of fuel left in 1 wing after a bunch of tipping.
Old Jan 26, 2013 | 05:50 AM
toyotabuilder's Avatar
i thought about doing the pump mod but decided that getting a kolpin fuel pack was more time and cost effective and less headache in the long run
Old Jan 26, 2013 | 03:02 PM
Ron, is that a cruise control? What's next?...a portapotty strapped to the rear rack?
Old Jan 28, 2013 | 01:54 PM
Ranger Ron's Avatar
Hmmmmm... Portapotty. Now you've got me thinking!
Cruise control?
Ron
Old Jan 28, 2013 | 01:57 PM
Attached Thumbnails Acerbis 3.7 gallon tank all fuel mod question-porta-pooper.jpg
IDRIDR
Jan 18, 2013 04:46 PM
dogfarm
Oct 14, 2012 04:23 PM
Martindktm
Jan 30, 2009 05:36 AM
WestOzKLX
Sep 12, 2008 09:00 PM
nc_650R
Jan 19, 2008 04:45 PM
