Acebis Dimension Install
Old Oct 21, 2008 | 11:46 AM
neilaction's Avatar
Default Acebis Dimension Install
When installing the Acerbis Dimension headlight, I chose to do away with as much "excess" stuff as I could.
I mounted the indicators to the headlight housing using existing holes.
The I wired both the indicators and the headlight to a common plug to enable the headlight to be easily removed.
As I was not connecting the high beam or parking light, a 4 pin plug was enough.
Maybe a 6 pin would be better for most people.
It's a very simple and light weight set up.
Old Oct 21, 2008 | 11:58 AM
WestOzKLX's Avatar
That's some tidy work there Neil.
Would love to get mine done too but I'm saving for another bike at the moment.
I need a bike for my old man when he visits so we can do a few trips together.
I wont be selling the KLX though.
Old Oct 21, 2008 | 12:59 PM
mc1457's Avatar
Very nice!
Where did you tuck away the turn signal relay? Is that the stock triple-clamp? The US version has a big bracket on the front where the ignition switch goes that I'd have to grind off. Where did you relocate the ignition switch? Or did you replace it with a toggle switch?
I like the idea of mounting the turn signals to the headlight housing itself. I think I can pull that off with the Cyclops. This solves half my problem. The other is mounting the Vapor. Then I can get rid of that heavy stock bracket.
Old Oct 21, 2008 | 01:28 PM
neilaction's Avatar
In the last pic you see the tin can strapped under the GPS mount?
That's the turn relay.
It's different to the stock one in that it's non load dependent.
I did cut away the alloy ring that was around the ignition switch and put a toggle switch in it's place.
This shows what I did.
And with the GPS mounted with the switch on it's left.
Old Oct 21, 2008 | 02:00 PM
redpillar's Avatar
Nice work!!
Old Oct 21, 2008 | 02:07 PM
neilaction's Avatar
Originally Posted by redpillar
Nice work!!
Thanks,
I did a write up on the whole ignition switch removal and GPS install a while back.
Here is a view of the underside of the bracket and toggle install.
Old Oct 21, 2008 | 03:20 PM
testify4's Avatar
How is everyone making these excellent looking custom mounting brackets? Do you just buy stock aluminum and use standard power tools, or does it require something special to do?
I've seen a couple Vapor mounts that look awesome, too.
Old Oct 21, 2008 | 03:23 PM
neilaction's Avatar
Old Oct 21, 2008 | 07:06 PM
mc1457's Avatar
Really nice work!
Testify - I used a hack saw, drill press, files, and aluminum stock picked up at a popular home improvement store.
Old Oct 21, 2008 | 08:09 PM
testify4's Avatar
I have one of those. Not as nice, but it cuts!
Gotcha- I will see what they have for stock at the Home Depot next time I am there. I'd like to mount up a Vapor sometime. My stock speedo is off by at least 5mph and I'd like the extra functionality. (Ok, I also like electronic gadgets...)
