90/90 21 On The KLX250S Front
Old Jan 2, 2009 | 11:58 AM
markcr's Avatar
Default 90/90 21 On The KLX250S Front
Has anyone successfully mounted a 90/90-21 front tire? There are a lot of good tires in that size but our front rim is only 3.0. However, the 80/100 that comes stock is 3.15. The 90/90 would be about 3.54. Not sure how much over you can go without running into problems.
Old Jan 2, 2009 | 01:07 PM
2k1w=no$'s Avatar
I could be wrong, but I think that the 90/90 is just about the same size as the 80/100. I don't think that you would have a problem with it.
Old Jan 2, 2009 | 01:47 PM
markcr's Avatar
The 90 is 10 mm larger (wider) than the 80 and I want to make sure it isn't too wide for the bead to correctly fit the 3.0 inch front rim.
Old Jan 2, 2009 | 02:16 PM
2k1w=no$'s Avatar
On paper its 10mm wider. Exact tire sizes don't always add up to the size that on the side of it.
I really don't see it as being a problem. From what I remember, there was a guy that went on a couple rides with us and he was running a Pirelli front tire. I think the Pirelli's only come in a 90/90.
Old Jan 2, 2009 | 03:24 PM
AgoosSS's Avatar
I typically run a Pirelli MT16 80/100x21, a good all around tire. I have also used a Pirelli Scorpion Pro 90/90x21 with no problems.
Old Jan 2, 2009 | 03:27 PM
markcr's Avatar
Cool. Thanks. I just wanted to make sure someone else out there has done it and hasn't had a problem with the tire sealing correctly on the rim. It opens up my tire options quite a bit.
Old Jan 2, 2009 | 03:37 PM
AgoosSS's Avatar
The only thing to maybe consider is tire sizes do vary slightly on occasion between manufactures. You should be OK.
Old Jan 2, 2009 | 04:15 PM
GreenMonsta's Avatar
Put 1,000 mi on a Kenda K777F 90/90-21 tire and it was fine.
80/100 is 80mm wide by 100% of 80 tall so it's 80mm tall.
90/90 is 90mm wide by 90% of 90 so it's 81mm tall
1mm (0.0394) taller and 10mm (0.3937) wider
Old Jan 2, 2009 | 05:07 PM
cliffsta's Avatar
I'm running a 90/90/21 front in the Dunlop 606. It went on just fine.
rkutzner
Dec 24, 2013 05:08 PM
TALLEN
Jun 1, 2008 03:50 PM
Sid Post
Apr 22, 2008 04:26 PM
35racer2
Apr 19, 2008 01:03 AM
Divodave
Mar 28, 2007 01:41 AM
