8000 RPM Rattle
Yeah, really loud. I have good hearing, but still... It's significantly louder (and worse far worse sounding) than the cam chain noise ever was.
Even with all the wind and normal bike noises at 70 mph or so WOT, I can hear it plain as day. Of course the lever is almost literally under my nose, so I suppose it should be relatively easy to hear.
I just pulled it apart and greased it, but it is pretty loose fitting and I suspect it will still be noisey. We'll see...at least I know what it is now.
Good jab! However...False! Even with two fingers on the clutch as normal, it still happens. It's only silenced with a significant amount of pressure, i.e. starting to pull the lever in, or pushing down on the lever. Just resting my fingers on top of the lever isn't enough pressure to stop it.
Glad you got it figured out, man.
Lutz, is your lever perch spread too far open or such? Also, hows the bushing in the lever itself? It sounds like there's a lot of play in there for some reason.
I'm not sure if it's the same part as the '06/'07 bikes, but it's actually quite rigid at the pivot bolt; in other words tightening the bolt does not cause the perch gap to close up, like it can on other bikes. On my old KDX, if the lever rattled, I could just tighten the pivot bolt to squeeze the perch together.
Eh, might as well update this again.
The grease at the pivot point did work to silence the clutch lever rattling...but only for a while. The rattle did come back as the grease was worked out of the pivot. Long term, I'll either keep greasing it periodically, or just let it rattle and know what it is...or maybe replace it with a different lever.
