7465 Mile Valve Check
Close enough for the 7500 tune-up. Anyway the intakes did not move. The exhaust did wear some, but they did it evenly. Here are the two valve checks I have done.
Now there is one error in this pic...Brian be quiet.
RE: 7465 Mile Valve Check
ORIGINAL: EMS_0525
so do mine, but the mm are like .15 then the next one is .20 they go in .05 incriments.... how do you get such an accurate #?
ORIGINAL: EMS_0525
that still didnt answer my ? though.... the mm ones go in like .05 incriments... ho do you get a reading less than .05 ?
The specs are from .100mm to .240mm in our valve train. When I get home today I will see how low my gauges go.
isnt the range from .15mm to .19 mm on one of the cams? im not sure how to measure that that precise to see what exactly it is... say i tried using the .15mm guage and its too thin, so i go up to .20mm gueage and its too thick how do i know exactly what the clearance is?
ORIGINAL: EMS_0525
exhuast: .150 -240mm/ .15-.25, .25 should never fit, .20 is your goal.
I that a better answer?
