351 kit jetting with stock exhaust for 09 KLXS
Need advice. I'm at 900' in So Cal. I have the Dyno jet kit and Kouba. Twin Air, removed snorkel and backfire mesh (which was a bitch). Stock exhaust and pipe. Later (when its warmer) I'll be running 4000' to 6000'. Suggestions for either would be helpful. Thanks
Now that will be an interesting setup. Surely there's one out there somewhere, but I don't believe I've seen anyone with a big bore kit and the fully stock exhaust. Most at least go to a slip-on muffler. I'm curious.
Good luck with it. Be sure and let us know how what you did and how it works out!
The stock setup exhaust is because I will be doing all my riding in the city for the next couple months. I also want to get a real baseline to compare with my anticipated KLX 300 Header ($108 from dealer) and exhaust ($75 used) to be added when I go to the mountains (I'll have to change the jetting anyway).
Wow...I would have guess the 132 would be too big with a stock exhaust. Oh, it's modified...obviously opened up, right? Do you think it would be even better with a 130, or even 128?
I like what you've done with the stock exhaust. It would be cool to see some dyno runs with your bike & your exhaust compared to stock and aftermarket stuff. Alas..money and time
Dyno time is next week. I have my pipe and a stock one to compare it to.
David
