320 rotor
Old May 9, 2016 | 06:41 PM
Matt88-8's Avatar
I know it can be done on the 09+ bikes with just a rotor and bracket. I'm curious if the ebc kit works on the first generation
Old May 9, 2016 | 10:27 PM
As said, the 300 mm rotor that is used on the KLX650C and the KLX250SF is a bolt on with the right bracket. One way to learn what works is to see what the bracket part number is on the 09 for both the S and SF, then compare to the brackets on the earlier models If the S brackets match that would mean the SF should work on the earlier bike. If not, it might be possible to use the fork leg from a 650C on the earlier bike.
Easiest and least expensive would be a stainless line and some softer high grip pads.
progrmr
Ninja 500R
Jul 23, 2007 11:46 AM
unclean title
Apr 17, 2007 07:51 PM
projectroc
Mar 21, 2007 08:52 AM
Jun 8, 2006 09:38 PM
joshs636rr
Nov 27, 2005 05:50 AM
