300R with 250S head?
Is there any advantage to the 250S cylinder head on an otherwise natural 300R?
Asking because I seem to remember the 250S head adding a little compression ratio to the mix. I know it works OK cause guys swap 300 cylinder/pistons onto the 250S all the time. Just wondering if there's any advantage? But then, at my age, I remember a lot of stuff that didn't really happen. Did I ever tell you about the time I dated Jan Brady..... |
The early KLX250 heads have smaller combustion chambers than the KLX300. I don't know about the newer "s" heads. The guide line that I've heard is that you might get a 3% increase in HP for each one point increase in compression ratio.........is it worth it? I'd put my money and effort into a big bore kit first.
Jan Brady from the Brady Bunch? Not sure you were her type. 'Brady Bunch' Star Reveals All About Lesbian Fling With TV Sister? - Starpulse.com Ride on Brewster |
Thanks Brewster. I looked it up and the CR is the same anyway. Like I said, my memory is subject to asthmatic fits.
Sure, Eve WAS a lesbian.....I turned her back to men. Yeah, that's the ticket..... |
