2014 swingarm question
Old May 27, 2018 | 12:07 PM
Doc's Avatar
Doc
Default 2014 swingarm question
Anyone know if a 2014 rear swingarm will fit a 2006? Did a little searching, but couldn't find anything?
Old May 29, 2018 | 11:31 AM
wildcard's Avatar
It should physically fit as the frames should all be the same, but I know Kawasaki changed the chain adjusting system so the axle might be different as well. You might also run into a problem where the rear brake mount is different.
If you can get one cheap it might be worth trying, but without the other associated parts it may not be a 1:1 swap.
Old May 29, 2018 | 01:15 PM
Rear brake carrier fits. I'm running an earlier brake carrier on my 2009 with the smaller 06-08 rear rotor. I'm betting all will bolt up as far as the pivot, but not sure about suspension linkage. You' have to look up some part numbers to verify fits. Go to Partzilla and look up the linkage, the hardware matches the hole sizes are the same, if the link numbers match it all plugs in.
You can fit the later model brake carrier and run the later model rotor, otherwise if you run the earlier version rotor you need the older model carrier. There is a 20mm difference in rotor diameters. I noticed my rear brake caliper was sitting too far up on my rotor, so I got one of the earlier carriers and it bolted together perfect, now the caliper has full sweep of the rotor.
Old May 29, 2018 | 09:04 PM
Doc's Avatar
Doc
So, if I understand KLX678 correctly, If i use my 06 caliber with my 06 rotor It should be fine as far as the brakes are concerned. I'm not too terribly concerned about the rear axle. The adjusters are part of the reasons for the swap.
Looks like the dog bones are different, but i don't see anything else here.
Old May 30, 2018 | 12:38 AM
wildcard's Avatar
That's how it sounds to me, if I am reading his post right. Since you have the old caliper mount/carrier and it fits in the new swing arm all you should need is the axle, chain adjustment plates and the new style dog bones.
Old May 30, 2018 | 01:49 PM
What I'm saying, that cannot be seen in the diagram, is if the bolts/bushing part numbers in full, that attach the swing arm to the linkage, match up the swing arm will bolt in.
I already know the caliper set up will work, since I have the 06 caliper/carrier on my 09 the 09 caliper/carrier will work on the earlier model.
Old May 30, 2018 | 09:56 PM
jansjetta's Avatar
I'm running 09-14 dogbones on a 2006 KLX to reduce the rear height. The only difference between the two is the 2006 dogbones are 117.5mm and the 09-14 dogbones are 119mm.
Old Jan 30, 2020 | 03:43 PM
Kwak's Avatar
Will 09-14 linkage arm fit 06 bike? It is part 39007 in pictures above.
Both parts look similar, but Kawasaki part numbers differ - #39007-1230 for 2006 and #39007-0100 for 2009...
Old Jan 30, 2020 | 03:55 PM
jansjetta's Avatar
I don't know about the part number you are asking about but I wanted to correct my previous post.
2006-2008 dogbones are 117 mm and 09 and up dogbones are 119.5.
I am still running 09 dogbones on my 06 to lower the ride height and have had no problems.
Contra472
Jul 15, 2019 01:25 PM
prakthad
Feb 6, 2019 07:44 PM
andyng
Feb 9, 2018 02:18 PM
klx678
Jan 30, 2014 10:01 PM
Jun 8, 2006 09:38 PM
