2009 KLX250sf headlight and tail light not working
Old Jul 21, 2020 | 10:35 PM
Austin Ballard's Avatar
Default 2009 KLX250sf headlight and tail light not working
It’s not the fuses and I’ve changed the bulbs I haven’t found any loose wires either only a plug with nothing connected by the fuel switch. The only wire connected to it is a ground wire(black and yellow) I need help!
Old Jul 22, 2020 | 02:58 AM
durielk's Avatar
Do you have a VOM meter?
1. start at the fuses for the headlight, check for voltage on the + and continuity on the -.
Old Jul 24, 2020 | 07:57 AM
dogmeat's Avatar
go to the key switch and start looking. check that the fuses are good and there is power to the key. thats the only place where the headlight & tail light circuits come together so if you have power to the key switch the problem is inside
you'll need a diagram and a meter
Old Jul 31, 2020 | 02:10 AM
azdeuce's Avatar
Meter is your friend...
Ti3m
Apr 26, 2020 02:31 AM
qxangelxp
Aug 6, 2016 10:59 AM
93Octane
Jun 19, 2015 11:39 AM
alexb123
Feb 10, 2013 08:56 PM
