2009 KLX250S running issues
Old Mar 22, 2012 | 01:57 PM
chad2787's Avatar
TNC: I have the stock 35 pilot jet. The three turns out was advised in the dynojet kit. I can still install another epa plug if I have to. I have access to a 38 pilot jet but would have to have it ordered for the correct carb, My parts guy sold me one for a different type of Mikuni.
rgoers: I did plug up the two vent holes in the air box, the vacume nozzle on the carb, after removing the EPA stuff, My bike is also a CA Model but with the starting issues, and the lack of get up when starting off at a dead stop, I felt it was a little lean. I also slapped on a 13T drive sprocket to get a little more start off torque.
But the KLX has to sit for a while now I need to finish my MX400 restore.
Thank you both for the help
Old Mar 22, 2012 | 05:13 PM
rgoers's Avatar
Just curious... was your fuel screw turned out 1.0 turns (as most people are reporting) or 2.5 turns like mine was??? Since mine was out 2.5 turns from the factory, I'm attributing that to my LACK of a starting problem (pre-DynoJet).
Post-DynoJet; I now have to choke to start every time. Before I jetted it, I used to be able to start without choking on warmer days (50F+). I'm going to leave it as-is for now.
Old Mar 22, 2012 | 05:36 PM
Three turns out may be the advised starting point, but if you can, spend some time adjusting it to find the sweet spot. That will tell you if you need a larger one. This is usually done by turning the idle up a bit, and finding the fuel screw setting that gives the highest rpm. I stop there. Some guys go just a little richer (I think) with 1/4 turn or so IIRC. If the sweet spot is 1 turn or less out, get a smaller pilot. If 3 turns or more out, get a larger one.
andrew1608
Jul 17, 2010 03:40 PM
kawikathy
Nov 21, 2007 01:10 AM
marilake
May 17, 2007 08:36 PM
Violet_Vixen
Apr 9, 2006 04:42 AM
Violet_Vixen
Jul 8, 2005 04:03 AM
