2009 KLX250S race sag, .46 and 6.2 Springs, 230 lbs rider
Old Feb 17, 2019 | 08:09 PM
Abramsgunner's Avatar
Originally Posted by geo
Difference between 06 07 and later models is the link (117 compared to 119mm) and travel (less travel needs more spring to have have the same force at the end of travel).
Stiffer springs do not give a stiffer ride unless you have gone too far. It's a myth generated by the inexperienced. The opposite is usually the effect and simple math will show it to you.
Find the rate per inch, add the preload value and that is spring force about 1/3 travel. Add one more inch of rate to the first number and that is spring force at about 2/3 travel,,, and so on.
Advantage of stiffer springs in off road use is the fact they require less preload to support you and the bike. This helps when off throttle on stuff like downhill logs,rocks and roots. IE if you have 150 lbs of preload on a stiff spring compared to 250 on a soft spring, that is 100 lbs less force trying to whack the seat into your butt as the rear is unloaded.
The 100 lbs less preload from a stiffer spring carries on through the travel as the spring rate builds during compression and eventually ends up higher in rate at the end but is not stiffer all the way through. We only have about 3" of total spring travel anyway.
Win win in comfort and control if dampened correctly.
My 07 and me (230ish) like .47 in the front and 7.2 on the rear. Front is preloaded 6mm and rear is preloaded just 8mm to get the correct sags. Plush and supportive.
If I have my low speed compression adjuster set loose I can bump the shock bump stop on a log at walking pace. Definitely not oversprung.
Update... 2+ years later...
So over time, as my skills have improved, I've made some changes and wanted to update for those who are confused about which springs to run on the '09+
I never lost any weight...reckon those days might be behind me.. lol
I've put a couple thousand trail miles on my '09 KLX, very few road miles as I have my Versys for that. I love singletrack and ride a lot of fire roads when I can.
I've now worked my way up to .48/7.0 and the bike feels more lively. I thought I liked the 6.6, but the 7.0 feels even better... perhaps Racetech is not too far off afterall
Side note: I also swapped in some '06 117mm dog bones last year. Not sure what difference that made in ride quality, but it was cheap and didn't have any negative effect.
Measured sag with the 7.0 was 80mm race sag with 25mm static.. I don't know how I got similar numbers with the 6.2.. I'll go back and edit that as inaccurate...
klx678
Feb 19, 2019 06:39 PM
Tin
Apr 22, 2015 10:30 PM
djchan
Sep 1, 2012 08:00 PM
Donnie
May 28, 2010 11:42 AM
FlyingFinn
May 25, 2010 12:52 AM
