2009 KLX250S not getting spark
Old Feb 29, 2016 | 11:40 PM
7layercooki's Avatar
Default 2009 KLX250S not getting spark
My bike isn't getting spark I replaced the coil and wire, spark plug, cdi box, and starter relay. I have followed the wires none of them looked messed up. The only thing I have not replaced was the stator. I wasn't sure if I should replace that or if there was another relay or anything I could replace to see if it works. If I cant get it fixed then ill take it to a bike mech. but would like to save some money. Would love help to get it back on the road again. Thanks
Old Mar 1, 2016 | 12:19 AM
Ruggybuggy's Avatar
Faulty kill switch or wire to the kill switch is grounding? Shot in the dark. Do you have a wiring diagram and/or shop manual?
Old Mar 1, 2016 | 12:24 AM
marcham's Avatar
Kill switch was my first thought as well...
Old Mar 1, 2016 | 12:31 AM
MaverickAus's Avatar
The stator should not stop you getting spark, look elsewhere
I have a shop manual on my phone ill track down those wires and see if that's the culprit I appreciate it
Old Mar 1, 2016 | 12:48 AM
durielk's Avatar
I forget, but I think if the kill switch is activated, the starter will not run. That is the way the beamer is.
Someone may check this as my kawa is in timeout.
Old Mar 1, 2016 | 01:43 AM
MaximusPrime's Avatar
Yeah, durielk is right, kill switch kills spark and starter. Best place to start would be that switch.
Is or has the kickstand safety switch been checked? Clean the switch with contact cleaner or check out how to disconnect it in the stickies.
Next check the neutral safety switch. First, that it's plugged in. This can also be disconnected, but will allow the bike to run the starter in gear with the clutch engaged.
Check and clean all the grounds on the bike.
Is the ignition still intact? If it's missing you'll need to add a resistor so the CDI will work (others have done this on this bike, I think), I had to do that to my old EX-500 when I had the same problem.
If all that has been done. And your sure it's still not got spark, then test the stator with a multimeter.
After that? Find a good mechanic and explain all you've done.
Good luck. It's probably something simple.
Old Mar 1, 2016 | 01:17 PM
I appreciate it guys I'll do some testing with the voltage meter when I get home from work
chadwalsh7
Jul 14, 2014 11:52 AM
Dezrider
Dec 7, 2010 09:48 PM
johnrhancock
Apr 15, 2009 04:07 PM
amstel422
Jun 21, 2008 06:20 PM
jayden
Apr 29, 2006 10:16 PM
