2009 klx250s backfiring after mods....
Old May 10, 2010 | 10:20 PM
benwiggins's Avatar
Default 2009 klx250s backfiring after mods....
yo! so my 2009 klx250s is backfiring when I drop off the throttle or engine brake. Is this just a result of the pipe? I installed an FMF Powercore 4 pipe and dynojet jet kit. It is on the third clip and I am about 2.5 turns out. The bike has the snorkel removed from the airbox. Should i drop to the second clip position and 2-2.5 turns out? I am at about 200o feet above sea level.
Old May 10, 2010 | 11:32 PM
armycopter's Avatar
Make absolutely sure there are no exhaust leaks both at the head and at the join.
Old May 11, 2010 | 04:20 AM
mattyw's Avatar
ben, search the forums for this. I have this issue when i pull the baffle out of the 300 exhaust i have sometimes. My understanding is that it is actually from a lean operating condition. I dont remember the reasoning and it seems counterintuitive, but i found a few sources that gave the same reasoning, and it seems to make sense being that i dont have the issue when i have the baffle in with some spacing washers. Does it typically happen going from high RPM and forcing the throttle closed?
Old May 11, 2010 | 04:46 AM
punkenduro09's Avatar
need to go up on the pilot jet.
Old May 12, 2010 | 09:32 PM
844simon's Avatar
try closing off the secondary air system. this allows air into the exhaust to help reduce emissions.the valve is located in the cylinder head just above where the exhaust pipe joins the head.
Old May 12, 2010 | 10:18 PM
armycopter's Avatar
However you decide to block this off, make sure it's tight and the gaskets are seated properly. I had decel backfiring after removing this system and didn't put the gasket on the blank off plate. The backfiring ceased immediately after I rectified this problem. That's why I also mentioned the exhaust system. Make sure it's sealed well. Good luck, you'll get it.
Old May 12, 2010 | 10:26 PM
ACOLE's Avatar
Default Decel popping
I fitted a two bros slip on and got alot of decel popping. Got some great advice from the forum.
Search the thread "Added new exhaust" by Winter737. Some good advice from Army Copter, Ramjet & Candyass.
Hope this helps.
Old May 12, 2010 | 10:30 PM
ACOLE's Avatar
Default Secondary Air System
Do you have a part number for that blanking plate.
Old May 12, 2010 | 10:50 PM
Arctra's Avatar
Hope this helps.
Here is the thread: https://www.kawasakiforums.com/forum...=Added+exhaust
Klxster
Nov 20, 2014 12:40 AM
tb865
Jan 26, 2014 08:20 PM
Klxster
Jul 31, 2013 02:50 PM
Klxster
Jul 31, 2013 11:10 AM
Lawnica1
Aug 14, 2010 06:37 AM
