2006 KLX 250 LED light upgrade
Has anyone installed LED lights into their 06-07 klx? I did the upgrade on my klr 250 several years ago and I was really pleased with the results. I'm only replacing the tail/brake, license, and dash lights. I'm not worried about the turn signals at the moment. I'm undecided on what color bulb for the dash would match the stock back lighting. So has anyone gone with LED lights in the dash and if so what color LED did you go with? Pictures would be great if anyone has done the swap, Thanks Fred.
Well I ordered some LED lights from superbrightleds. I ordered from the same place when I did my klr250 LED swap. I'm hoping once they show up I can get them installed by the weekend. I'll post up a brief overview of how I like the LED's and which color I end up going with.
I did check the amps each of the old bulb's draws. This is one of the reason's I'm switching to LED for the less current draw which frees up power for anything else I might want to put on the bike in the future.
Four dash back lighting bulbs each one is 1.7 watts x 4 = 6.8 watts or 0.5 amps
Neutral green indicator light in dash 1.7 watts or .012 amps
High beam blue indicator light in dash 3 watts or 0.22 amps
License plate light 5 watts or 0.37 amps
1157 Tail light bulb 8 watts or 0.6 amps
1157 Brake light bulb 28 watts or 2.07 amps
So I should be able free up some amps with doing the swap. The total of all of these bulb when on is about 52 watts. Fred.
I got some of the LED lights installed. I'm still debating on which color to go with on the speedometer and tachometer.
This first picture is cool white and seems the closest to the factory color.
This one is cool white on the speedometer and green on the tachometer.
This last one is green on both sides.
I think I like the cool white. I'm going to do some riding at night to see which color I like best. I did this in my garage with the lights off trying to see what I liked better. I think a riding test at night will determine the color.
I also swapped the high beam indicator and neutral indicator light as well for LED. The brake light and license plate light where also changed for LED. If anyone wants to see a before and after I could take a picture of the difference.
I'm going to check the current draw of these LED bulbs before I do the final install and I'll post up the difference over the incandescent stock bulbs.
74 LED Bulb - 1 SMD LED Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
