2 Audio Requests
Old Jun 2, 2006 | 10:26 AM
bryantjt's Avatar
Default 2 Audio Requests
Hey I was wondering if you guys with the Muzzy and Big Gun setups could do one more audio clip each. The Muzzy audio clip on here now is a 2,4,and 6000 static test. Could you do a static test revving it up to 6000 and back to neutral similar to klxstifflers big gun clip?
For those of you with the Big Gun could you do a 2,4 and 6000 static test to match the Muzzy clip on here now? I'm just trying to compare apples to apples so to speak, right now the Big Gun clip gives me an idea of what it will sound like when accelerating, while the Muzzy is good for highway cruising speeds. From what I've heard so far on the clips the Big Gun seems a tad quieter even though the manufacturers rate them both 94-96 db with their respective quiet and spark arrestor inserts.
Old Jun 2, 2006 | 12:53 PM
MaverickAus's Avatar
Default RE: 2 Audio Requests
under load would be more usful IMHO
Old Jun 2, 2006 | 08:20 PM
bryantjt's Avatar
I agree under load would be more useful but somewhat difficult to do unless you just set the camera somewhere and rode by, but under no load conditions if one was louder than the other, I'd imagine they would be the same under load conditions, with the loud one still being louder.
Old Jun 3, 2006 | 01:30 AM
Hopefully this will be helpful. I made few clips with the camera mounted in the same spot, one of the stock exhaust and one w/the muzzy installed. The clip shows both going away from the camera and back toward the camera, and then away again. It is pretty representative, but just remember the little microphone on this camera is not that great and neither exhaust is really super accurately represented. However, hearing them together with the same equipment under the same conditions (as best I could) with varying engine load, etc, should help.
You can find it HERE.
Edit: link no longer works
Old Jun 3, 2006 | 05:25 AM
bryantjt's Avatar
Wow the Muzzy has a great bark to it. Thanks NB! Now to find someone with the Big Gun to do the same thing.
Worlok14
Feb 5, 2009 06:15 PM
Sawbuck
Apr 8, 2008 12:32 AM
srobak
Sep 22, 2007 03:46 AM
bryantjt
Sep 19, 2006 12:52 AM
