1st hard starting, now wont stay running
Old Jun 3, 2007 | 07:40 PM
KFalc's Avatar
Default 1st hard starting, now wont stay running
Well, I finally had a chance to take my bike out of the basement this weekend. Buried behind all the stuff from the basement i am remodeling...
Anyway, I was having a heck of a time getting it started. I drained all the gas (from last year), emptied the float bowl, and put in fresh gas, removed and cleaned the spark plug, and got it running with a jump from the car.
The first time i had it started I let it idle, adjusted the idle, and let it run for about 3 minutes before it just shut off. It wouldn’t start right away after that. I gave it about a 1/2 hour, drained the bowl again, and it fired right up without a jump. But the same thing happened again after a couple of minutes. Repeated process again, and took it for a ride down the road thinking it needed to be cleared out. It stalled out after about 3/4 of a mile. I was at the top of a hill (luckily) but it wouldn’t pop start either.
Any ideas you guys have would be welcome...
Cheers,
Kris
Old Jun 3, 2007 | 08:30 PM
boxermachine's Avatar
Default RE: 1st hard starting, now wont stay running
Sounds like a bad float. A big pain to tear that carb out of there. Try again w/ the simplest things 1st- new gas (again), clean plug- double check everything ect...
Old Jun 5, 2007 | 01:40 AM
2k1w=no$'s Avatar
The carb is not really a big deal to pull off if you have to. Try tapping lightly on the float bowl it might free things up.
Old Jun 5, 2007 | 07:45 AM
Truckman's Avatar
That's exactly what i was going to suggest.A couple good taps from a screwdriver handle usually works best with the gas turned on.
Old Jun 5, 2007 | 01:29 PM
poodlenuts's Avatar
re-adjusted the idle,it maybe set to low
royhootgibson
Classic Sportbikes
May 18, 2010 01:28 AM
ranger257
Jun 7, 2009 12:06 AM
oldryder
Jul 22, 2008 03:19 PM
preemo_21
Ninja ZX-7R
Oct 3, 2006 12:43 PM
mbz300sdl
Apr 9, 2006 06:42 PM
