13T Front Sprocket Speed?
Old May 2, 2012 | 03:44 PM
Websurfing101's Avatar
Default 13T Front Sprocket Speed?
Was thinking about adding a 13T front sprocket to KLX 250s. I would like to get some more low end grunt, but still need highway speeds. What kind of top speed can I expect from changing the front sprocket to a 13T? I Have no plans on changing the rear sprocket. How much will this modification change my speedo? Also, wanted to know what the RPM range will be also? (13/42T)
Old May 2, 2012 | 03:57 PM
jeffzx9's Avatar
When you get that one figured out, let me know.....
Old May 2, 2012 | 04:06 PM
Just wanted to get a ball park range? I don't want to get blown away on the highway by Prius.
Old May 2, 2012 | 04:23 PM
ahnh666's Avatar
if the top speed on a stock klx250s is 75 mph...you'll get blown away by a prius on the highway....if you are reducing your front sprocket, you'll reduce your highend even more...so, you'll get blown away by a 250 scooter on the highway...
Old May 2, 2012 | 04:24 PM
2007KLX250S's Avatar
When I had my 13 tooth on I actually could get to and maintain highway speeds better but it was around 500+ rpms higher at any given speed. I now run the 15 tooth to lower rpms since I mostly commute at the moment. Its a little harder to maintain speed if there is a head wind though unless i tuck for aerodynamics
Old May 2, 2012 | 04:38 PM
ahnh666's Avatar
i noticed same...front sprocket change is about 500 to 600 rpm +/-....and, if 1 size in front is equal to 3 in back sprocket....going up or down 3 sprockets on rear is about 500 to 600 rpm +/-
Old May 2, 2012 | 05:01 PM
What is peak RPMs on the bikes?
Old May 2, 2012 | 05:11 PM
ahnh666's Avatar
it's not on your bike?..i think it's 10,500 rpm...
Old May 2, 2012 | 05:22 PM
What is the best maximum shift point on the bike? 8500 RPMs?
Old May 2, 2012 | 05:45 PM
ahnh666's Avatar
if you saw dynobob's dyno graph, you should see it's at 7,500 to 8,000 rpm...
