'13 KLXs Won't go into first.
Old Sep 7, 2013 | 09:32 PM
DamageInc4x4NY's Avatar
Default '13 KLXs Won't go into first.
I dropped my bike, somewhat hard hit, bent the stock shift lever, and now it will only go into first sometimes. Is there an adjustment I can mess with or did I break something? Every other gear shifts perfect and it hits neutral perfect. Re-bent the lever for now (ordered an aftermarket one) and it's not hitting anything, just won't hit first every time.
Thanks!
Ben
Old Sep 8, 2013 | 01:07 AM
linkin5's Avatar
See the thread about the shift star, you need a new one and the older model is the better one.
Old Sep 8, 2013 | 01:19 AM
mrman's Avatar
Had a friend had this problem years ago.When shifting don,t push shifter toward engine,just push straight up and down.
Old Sep 8, 2013 | 06:30 AM
linkin5's Avatar
His issue is more serious than poor technique.
Old Sep 8, 2013 | 05:22 PM
Most likely it is a bent post that limits the shift fork movement. I had the same issue. inexpensive part and fairly easy fix.
Dan
Old Sep 8, 2013 | 05:29 PM
I did a write up on my experience here, https://www.kawasakiforums.com/forum...ar-gone-34237/
Using the search function on here will usually lead you to an answer.
Old Sep 10, 2013 | 03:11 AM
Lutz's Avatar
Originally Posted by DamageInc4x4NY
I dropped my bike ... and now it will only go into first sometimes. ... just won't hit first every time. ...
Sorry to hear you're dealing with what is (in my opinion) the Achilles heal of the KLX: the transmission.
If it goes into a particular gear sometimes, it's not a broken shift star.
Dan
I did a write up on my experience here, https://www.kawasakiforums.com/forum...ar-gone-34237/...
I agree with Dan, this is the most likely scenario.
Old Sep 12, 2013 | 11:13 PM
Dan
Winner winner! Thanks a bunch, mine is slightly bent so that's why I can sometimes get into first.
Now to get the part and put it in!
Ben
Old Sep 12, 2013 | 11:29 PM
Do you by any chance remember a part number?
Old Sep 13, 2013 | 03:46 AM
I usually can't even remember how old I am, you'll have to look it up yourself. Bikebandit.com , and other sites, sell OEM parts, and have the factory parts fiche available to look at online.
Glad it wasn't something worse.
Dan
Bayou220
Feb 26, 2014 12:08 AM
H. Vince
Apr 11, 2012 04:45 AM
h8hoos
May 5, 2011 03:49 AM
gunguy
Apr 21, 2011 02:50 PM
crash
Jun 6, 2007 04:33 AM
