'13 KLX250s Light Bulb , 80/100
Old Oct 4, 2013 | 09:17 PM
daren1093251's Avatar
Default '13 KLX250s Light Bulb , 80/100
Ok, a friend gave me a light bulb so I would stop complaining about how i see nothing at night. He got me a 80/100, is this too much for the stock wiring or am I good to go? just plug and play? thanks!
Old Oct 5, 2013 | 05:22 PM
NorCalKLX's Avatar
Wish I could tell you for sure but my only experience is for cars. Typically these types of bulbs run hotter and can melt plugs or wiring harnesses right behind the bulb. The wiring quality seems to be decent on our bikes but I've never ran a bulb like that before. I wanted better lighting so I choose a Silver Star Ultra and had great results, wattage is the same as factory though.
I'd run run the bike for 15 to 20 minutes with it on high beam with the stock bulb and monitor the connector behind the bulb, then run the other bulb for 20 minutes and see if it's noticeably hotter. If it's unbearably hot to the touch that might be to much. That's my guess. Hope it helps.
Old Oct 5, 2013 | 06:32 PM
Fuller_Malarkey's Avatar
Dunno about your wiring, I'd be concerned about switches and lenses. Your money, your call.
DDM Tuning : Motorcycle HID Kits & Lighting
Don't cut your way through the dark. Own the night. After three deer v. motorcycle incidents, I want all the advantage I can get.
Old Oct 9, 2013 | 05:15 PM
JaMan's Avatar
I assume you have one of these installed; what options did you choose when you ordered? Bulb wattage, type, color,etc...
skelator
Apr 22, 2014 03:28 PM
ahnh666
Jun 6, 2012 04:11 PM
Malves
Apr 26, 2011 03:46 PM
pie4foou
Feb 1, 2008 12:53 AM
aszrael1266
Oct 23, 2006 08:16 AM
