100 Octane
Old Nov 10, 2013 | 09:22 PM
Higher octane is used in high compression motors because the compression can cause combustion just like heat. If the octane is low, it will combust at a lower pressure than higher octane. the pre combustion causes the ping or knock. This can also be attributed to having a motor run so lean that a spark plug heats up like a glow plug and ignites the fuel without a spark.
Did you stay at a Holiday Inn Express too?
Old Nov 10, 2013 | 09:34 PM
RockabillSlapMatt's Avatar
Yes...
Old Nov 10, 2013 | 09:52 PM
Originally Posted by TNC
Sounds logical but I don't think it's that simple. Lower octane fuel is more volatile in its nature of how it ignites initially, but it has less uniformity in its burn characteristics from that point on. Higher octane has more stable ignition and overall burn characteristics which is more critical for engines with higher compression and/or more aggressive ignition timing. Now, you know I'm no engineer, but I hope I've learned something over years of messing with carbs, FI, and aftermarket ignition systems. And...I stayed in a Holiday Inn Express last night.
I don't know about that, TNC. I thought you slept in the back of your van. Pics and a receipt or it didn't happen.
dsm3383
Ninja 650R
Aug 8, 2008 02:28 PM
Chuckadian
Feb 19, 2008 12:43 AM
pie4foou
Feb 1, 2008 12:53 AM
MAD KAW
Sep 15, 2005 11:45 PM
TATTOOZIT
Jun 21, 2005 04:44 AM
