'09 KLX250s fork teardown pics
I've searched and searched but have not found any clear posting of pics of the internals of the '09 S forks when disassembled. Can someone point me to this info and also to any specific shim pack/compression valve changes short of Gold Valves or Moto-Pro valves to reduce the sharp compression spike? Thanks
There's this...
https://www.kawasakiforums.com/forum...acement-32443/ It's the older model, but should apply. Can't help with the mod info. |
Doesn't Moto pro have tech line for questions?
I should have been more specific, I was hoping to see pics of the actual compression valve assembly and the damper piston assembly. Thanks for your replies. I have talked with Moto-Pro and it was helpful, would just like to see some actual pics, can't find any. I will take some and post them when I finally get to tear down the forks but that will be some time, other things are getting in the way right now.
| All times are GMT. The time now is 02:07 PM. |
