'09 headlight question
Old Jul 30, 2008 | 09:12 PM
klxrdr's Avatar
Default '09 headlight question
The headlight on my klx450r is awful, all form no function. I'm just wondering if the headlamp on the '09 klx250 is as good as the one on my '07 is. If so i will just order the factory '09 light.
thnx in advance
Old Jul 31, 2008 | 02:33 AM
f1rocco's Avatar
The 09 headlight is probably the thing I hate the most...Looks cool though...
Ive used the screws for adjusting but either my low beams are to high or the highs are too low...I havent tried adjusting it too much but its annoying in high beam mode.... Useless..
Old Jul 31, 2008 | 12:58 PM
Old Jul 31, 2008 | 01:03 PM
tremor38's Avatar
thnx in advance
I believe the KLX450r comes with only a 35w bulb and no wiring for high beam, doesn't it? I know of one forum member (Redbird) that fitted the KLX450 light fixture to his KLX250s, but with one change... he just plugged the stock 55/60W high/low beam KLX250s bulb and harness into the KLX450 fixture and reported very good results.
I also know of somebody here in Japan who put the KLX450r headlight fixture on a D-tracker then fitted it with an H4 based hi/lo H.I.D unit...that son-of-a-gun is THE BOMB and is on my short list for future mods.
So, to some it up, I'm pretty sure the problem is your bulb. If you can find an H4 harness, an H4 55/60w halogen bulb will work wonders. You will have to add a hi/low beam switch if you want the high beam function though.
Old Aug 6, 2008 | 10:49 PM
klxrdr's Avatar
I already have a 55w high\low bulb and a corresponding switch. It's just that the way the headlamp is shaped, it directs all of the light out the sides of the lens and also about 15 ft into the air. I have tried to shim the housing and adjust the bulb to no avail. The way it is designed the light only sits about a half inch above the fender so I think the fender is reflecting the light back up and away.
I guess if the '09 klx250s light is no good either i will just have to buck up and put one of those nasty looking Trail Tech rally looking lights on.
I like that old school look anyway.
Thnx for your input guys.
Old Aug 7, 2008 | 01:36 AM
f1rocco's Avatar
Might not be bad....
I havent used High beams much since because low beams are about 95% ideal..But under 20 mph the high beams rock....Maybe I was wanting some street bike or caged light that blast 100yards out...Offroad this headlight would probably rock...
**Note to self...
**Take country seasonal road cruise at 3am this weekend and try atv trails for 100 miles....**
Old Aug 7, 2008 | 08:38 PM
cliffsta's Avatar
Yeah I'm completely unimpressed with the headlight on my '09. It was adjusted far too high from the dealer... the low beam was hitting miles beyond where I could see, and the highbeam was signalling for Batman...
I've adjusted the beam WAYY down, still not that great (compared to my dad's '06 DRZ400-S) The problem to me is that the highbeam is too tight of a beam and doesn't shoot to the sides very well, especially in that mid-range where the lowbeam doesn't quite reach.
Old Aug 7, 2008 | 08:44 PM
Yeah im not to impressed with the light on the 09 as welll,, I think Kawi was more concerned with the look and not how it will help us see at night... It drives me crazy.. IVe adjusted and adjusted but it flat out sux...
but other than that I love my KLX
Old Aug 8, 2008 | 12:20 AM
klxrdr's Avatar
The lamp on my '07 klx250 rocks, maybe I should just retro fit one to my 450 but i wonder how cost effective it would be.
again thnx for chiming in guys
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
Savagekilla
May 16, 2008 10:22 PM
CALISAKI
Sep 20, 2007 05:50 PM
driven95lx
Ninja 500R
Jul 20, 2007 03:54 PM
