06' KLX250s Jet/Exhaust upgrade
Old 06-24-2009, 03:34 PM
Dubl-A's Avatar
Question 06' KLX250s Jet/Exhaust upgrade
Hello All,
Virgin post
Ive searched quite a bit on the upgrade options for my 06' and havent found too much solid info so I'll just ask what I cant find/dont understand here.
My KLX obviously needs to be opened up, ive already removed the snorkel and removed the butt plug (for now) and it seems to have helped a bit. I still need to do the crank case breather mod as well.
I do however want a jet kit installed on my carb and a new exhaust pretty soon to really let her breathe.
1). I live at 5-6k elevation and would ride to 7-8k occasionally, do I need a specific jet kit for this? If so which one/Part# do you recommend?
2). Ive read plenty on the slip-on -vs- full system exhaust and Im leaning towads a slip on, probably a HMF pipe, anyone have experience with these?
3). If I had a local dealer install the jet kit and exhaust, do they typically make sure all air/gas/etc mixtures are correct?
Sorry for sounding ignorant, im still trying to get my head around all this. Thanks in advance!
Old 06-24-2009, 03:44 PM
I didn't waste time on the "Free mods", no offense, but I just didn't want to screw up my own bike. Most of the owners out there have installed a full pipe, and jetting. Gear changes also made a great change to the power. I love the bike even more than the day I brought it home. Oh and welcome to the forums. Glad to have you aboard.
Jetting 132 & 40
Full Muzzy
Air box lid off
13-45 gears
Old 06-24-2009, 05:20 PM
testify4's Avatar
Welcome!
I think you will find opening up the other end of the bike will help a lot. Tuning for the higher altitudes will help, too.
When I first picked up my '07 KLX 250, I found it was running a bit rich. (Based on the fuel smell from the exhaust and reading the plug.) I am at 5k feet, so I figured I'd need to factor in some leaning out as I tuned.
I started with a UNI filter and the short KDX snorkel. That improved things- no rich fuel smell, chocolate brown plug, but still some backfiring when backing out of the throttle.
I recently installed a FMF Q4 exhaust, and...wow. It improved the midrange incredibly, and I can feel more acceleration on take off. Pulling out of turns has improved greatly. (And it sounds awesome- at idle, it sounds like a helicopter hovering. At WOT, it's not too loud but does turn some heads!)
Now I am running a tad lean- no problem, I was planning on rejetting with the exhaust, anyway. I am doing it with factory Kawi parts: 125 main, 40 pilot, N1TC needle. I'll dial the fuel screw out 2 turns. I might try a 128 main instead and step up if needed, but it seems like I am just a bit lean right now and I don't want to overdo it.
Old 06-24-2009, 08:14 PM
armycopter's Avatar
testify,
Did you install the full FMF? I just ordered the Q4 slip-on but won't have the $$ for the header for a while. I'm hoping to get some performance boost from just the slip-on. I've already re-jetted.
Old 06-24-2009, 09:15 PM
Dubl-A's Avatar
Thanks for the replies guys, although I dont think I got an answer on my questions...
Old 06-24-2009, 11:20 PM
nixlux's Avatar
1. Yes, but i live in Australia and most of my riding is just above sea level. Maybe some US guys can be a bit more specific
2. Depending on your budget. I went with a slip on and it made a noticable difference but i haven't tried the full system to compare.
3. If you ask the dealer i'm sure they'd whack it on a gas mixture machine and tune it for you when doing the rejet.
Welcome and hope that helps
Old 06-25-2009, 02:39 PM
Dubl-A's Avatar
Cool,
I wonder if they typically charge for that mixture machine. Damn this **** is an expensive hobby
Old 06-25-2009, 02:54 PM
testify4's Avatar
Originally Posted by armycopter
testify,
Armycopter-
I just went with the Q4 slip-on. I couldn't justify the price of the P-Bomb header at this time.
I believe you will be pleased with the FMF slip on- I could tell an immediate difference on the butt-dyno. Definitely an improvement in power. I can't wait to get the jets on this weekend and see if it gets even better.
Make sure you pick up some high-temp silicone to seal the pipe to the header if you don't have any around.
Old 06-25-2009, 03:25 PM
Dubl-A's Avatar
Originally Posted by testify4
Armycopter-
What jet kit are you going to run? What alt are you at? And last but not least, where do you get that high temp silicone?
Old 06-25-2009, 07:13 PM
testify4's Avatar
I am going to run Kawasaki factory parts for the 40 pilot, 125 main and N1TC needle, collar and clamp.
125 main jet: 92063-1069
N1TC Needle jet: 16009-1912
Needle Collar: 92143-1667
Needle Jet Clamp: 92037-1401
40 pilot jet: 92064-1108
Parts were a under 30 bucks.
I might pick up a 128 while I am there, just in case it's leaner than I thought at WOT.
I am at 5,000 feet, some riding goes up to 7,000 when I go canyon cruising.
I picked up the high temp silicone at Autozone- any auto parts place should have some. There was a copper and a black silicone available; I went with the black. It sealed perfectly once it cured, so I am happy. I did a test fit without the silicone and there were small leaks around the collar.
Quick Reply: 06' KLX250s Jet/Exhaust upgrade
