"Grease Trick" for Oil Filter Spring
Old Sep 6, 2006 | 06:21 AM
cwgoff's Avatar
Default "Grease Trick" for Oil Filter Spring
I have changed the oil & filter once on my KLX250S (at about 25 miles - Motoman style breakin). That time, I laid the bike on it's left side in order to hold the spring in place while setting in the new filter. I had read about the "grease trick" to hold the spring in place during re-assembly, but I did not know what kind of grease to use. I know it sounds goofy. Grease is grease, right? Well, I am not willing to take that chance when putting something directly into my bike's engine.
With that said, exactly what kind of grease do you "grease trick" folks use?
Thanks,
Chris
Old Sep 6, 2006 | 06:29 AM
FM_Thumper's Avatar
Default RE: "Grease Trick" for Oil Filter Spring
I used a Bel Ray all purpose motorcyle grease that I've had for years. You can just as easily use bearing grease as well. You are only putting a very very light dab just to hold the spring. It will dissolve and stay in the filter anyway.
Old Sep 6, 2006 | 06:30 AM
jsac's Avatar
i just used standard bearing grease... dont think it really matters tho as ull only need a dab of it to hold the spring in place
edit:
beat to the punch [8D]
Old Sep 6, 2006 | 07:25 AM
I heard somewhere that plain old Vaseline is the best and will dissolve right away.
Old Sep 6, 2006 | 05:26 PM
Jacks Dad's Avatar
I held the spring in place on the filter with a length of dental floss. Set the filter in it's home, seat the spring, slide the floss out.
I just couldn't bring myself to introduce Vaseline into the innards of my new engine.
Old Sep 6, 2006 | 05:32 PM
Cowboy 6's Avatar
Ewwwwww! Vasaline !!
Old Sep 6, 2006 | 05:33 PM
cwgoff's Avatar
That's a dang good idea right there. Now I finally have a use for that floss that my dentist gives me every time I go see him.
Funny story - I saw a comedian talking one time about going to a dentist for a cleaning. When the hygenist asked him when was the last time that he flossed his teeth, he said, "you tell me, you did it". bah-dum-bum.
Seriously, I will be using the floss on my next oil change. I am with Jacks Dad on this one. I don't want Vasaline or anything else like that in the engine. I am too paranoid for that. Every little hiccup I would blame on that grease.
Thanks all.
Old Sep 6, 2006 | 06:05 PM
Why doesn't Kawasaki just have the spring welded on the filter and charge another 25 cents each? I really think they dropped the ball on this one. Has anyone ever seen anything like this before?
Old Sep 6, 2006 | 06:18 PM
FM_Thumper's Avatar
ORIGINAL: deej
[sm=funnypostabove.gif]
[sm=laughat.gif]
Old Sep 6, 2006 | 06:39 PM
ORIGINAL: FM_Thumper
ORIGINAL: deej
[sm=laughat.gif]
THat's just wrong, why?????
