rejoining crankcases
Old Dec 7, 2013 | 10:53 AM
jonwilli's Avatar
Default rejoining crankcases
Hi
does anyone have any experience of re joining the crankcases. (KLR 250 1989) UK
I have fitted new main bearings to the crank
I fitted the left hand main bearing into the case. the right hand i fitted to the crank as the gear had to be fitted after the bearing install. I froze the crank and heated bearings to fit.
I heated the left hand inner bearing and the crank slid through nicely
I now need to put the cases back together. This means that the right hand bearing with the timing and balance chain gear has to be got into the casing. I cant heat the case in the oven as the output shaft seal is fitted and dont want to damage it.
I can heat the case with a propane torch but fear this will not be enough to get the bearing seated easily in the case.
Any suggestions would be much appreciated
Regards
Jon
Old Dec 7, 2013 | 02:54 PM
jonwilli's Avatar
Default problem solved
Sorted it. Heated case with blow torch and bearing seated easily
Old Dec 7, 2013 | 03:55 PM
Nothing quite like success. Good to hear your problem is solved.
Robbieag09
Jun 29, 2008 06:19 PM
