Need valve adjustment specs '04 KLR250
Old Sep 18, 2012 | 04:19 AM
klover's Avatar
Default Need valve adjustment specs '04 KLR250
Do I have shims? What is the clearance I need?
How do you do the tensioner?
Where do I get a service manual?
Thanks!
Old Sep 18, 2012 | 04:59 AM
MaverickAus's Avatar
Here you are. Valve Clearance (engine cold) should be: 0.20-0.24mm (.008-.009inches) for BOTH intake and exhaust.
Fundamentally, valve clearance adjustment is performed at piston TDC when ALL VALVES ARE COMPLETELY CLOSED.
In this configuratin, the dot on the exhaust camshaft sprocket is at "9:00," pointing straight ahead, and the dot on the intake camshaft sprocket is about 3 degrees shy of "3:00."
The feeler gauge fits between the rocker arm set-screw and the valve stem.
The "T" on the flywheel shouldn't move during the procedure, but if it's CLOSE to the TDC position, no biggie.
Oh, and there are 43 cam chain pins between the "9:00" sprocket tooth and the top of the "3:00" sprocket tooth; the 44th cam chain pin is beneath the 3:00 sprocket tooth.
Old Sep 18, 2012 | 10:10 AM
klover's Avatar
Default Thanks Maverick
Is the cam chain tensioned with a spring? On some Hondas I simply undo a bolt to allow the spring to tension, then tighten the bolt. Is it the same on this bike?
Old Sep 19, 2012 | 08:32 PM
klover's Avatar
Default any tune up threads for a 250 KLR?
proly been done.
Thanks.
BigFatRat
Jun 21, 2010 07:35 PM
My.klr.jr
Jan 18, 2009 06:57 AM
Notstock
Jun 23, 2006 01:01 AM
Marty
Apr 26, 2006 06:05 AM
lemac
Apr 22, 2006 07:05 AM
