Which feeler gauge?
Old Oct 21, 2022 | 04:27 PM
Weldingseabee's Avatar
Default Which feeler gauge?
I have two sets of feeler gauges one of the blades on one set reads (.020 .508) and the other blade reads(.20) I know the manual states to set at .20 for intake and exhaust so I just want make sure I use the right one. The (.020 .508) blade is the thicker of the two and has a bend. The (.20) blade is quite thin.
Old Oct 21, 2022 | 08:49 PM
I don't know the actual values, there is a range, but I'd go with the thicker of the two. Valves will lose clearance if anything, as the valves will wear into the seats if they wear, making the clearance less. I usually will set to the middle or a bit more on the valve shimming for that reason.
tksmith
Nov 1, 2020 11:13 AM
Sebastien Nailen
Jan 21, 2020 12:29 AM
dcorlando
Oct 18, 2006 06:01 AM
Notstock
May 30, 2006 07:17 AM
finishguy
Mar 13, 2006 01:46 AM
