KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Rear differential leak
Old Jan 11, 2022 | 11:43 PM
drew7811's Avatar
Question Rear differential leak
Recently, I changed out my front and rear differential fluids on my 2021 Mule Pro MX EPS. I think I might have accidentally overtightened my rear drain plug when installing it and now I have noticed a drop or two of fluid on the ground right underneath said plug. Without draining it to evaluate the plug, does anyone have any solutions on what will need to be done to solve this slow leak? Thank you in advance.
Drew
Old Jan 12, 2022 | 12:47 AM
I would drain out the rear diff fluid into a clean container for reuse. Evaluate your diff threads, copper washer if used, etc. Make sure that everything is clean prior to disassembly. A slow drip would bug the H*ll out of me.
Welcome to KF
liggett84@gmail.com
Apr 14, 2021 04:43 PM
terrib972
Oct 1, 2020 10:40 PM
8milereb
Sep 11, 2018 08:40 PM
Richard 1667
Jan 25, 2018 06:01 PM
jrichtha
Nov 25, 2015 07:49 PM
