KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Need help kx125 clutch adjustment
Old Jan 29, 2014 | 05:21 AM
settik's Avatar
Default Need help kx125 clutch adjustment
Hey guys i have a 1990 kx 125 and the clutch doesnt start to disengage until 3/4 of the way out. I replaced the clutch plates and it still didnt fix the problem. Theres puddy on the crank case holding the plastic outer casing of the clutch cable where the bracket is supposed to be(i bought it like that) just before it connects to the clutch case. The adjustment on the clutch lever is all the way out, if i screw it in even a lil the cable has a LOT of play. Should i adjust the one on the clutch cable behind my number plate further out or further in?
taxonomy
Aug 17, 2015 02:02 PM
schmidty1447
Mar 19, 2013 08:46 PM
ds33
Oct 9, 2012 10:21 PM
amck
KX125
Jan 17, 2011 05:20 PM
kawicole
KX125
Jan 7, 2008 03:48 AM
