KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
blow out oil
Old Dec 22, 2011 | 11:39 AM
tonhgpz's Avatar
Angry blow out oil
Hello i lust can't find out or know why the oil is blowing out of the air breather
this is really puzzling me HELP HELP.
Old Dec 22, 2011 | 12:36 PM
jeffzx9's Avatar
Ton, your crankcase isn't "breathing" properly. That means pressure is building up inside and blowing out the only place it can go. Check your venting line(s).
Old Dec 23, 2011 | 12:36 AM
tonhgpz's Avatar
Well jeffzx9 the only vent lines i know of r the ones on top of valve cover, is there any more that i don't know about, would love 2 know so i can check those out, Thanks
Old Dec 23, 2011 | 07:19 PM
jeffzx9's Avatar
I'm no expert on the '84 GPZ900, Ton. Going back thru your earlier posts, it looks like you took off the carbs to clean them. Any chance of a mis-routed vacuum/pressure EQ line on re-install? You also indicated "it ran great" for a short period of time after the cleaning. What changed? Anything pinched? (Any unfriendly rodents chewing or building nests in places they shouldn't?)
Old Dec 24, 2011 | 02:22 AM
tonhgpz's Avatar
I'll go back & back track everything i did, but the only thing i did change was i routed
the 2 hoses off the top cover & ran 2 hose to one to the air box like it should be at
least that's what i was told, but i'll check it out, & Thanks for your info. i'll kept u updated
Corey John Schweikert
ER 6N
Feb 6, 2013 12:03 AM
Worlok14
Dec 22, 2010 02:40 PM
deej
May 26, 2006 04:46 AM
jimmys250R
Ninja 250R
Apr 4, 2006 11:54 PM
ArataOGK
Jun 20, 2005 08:57 PM
