KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
2006 kx 65
Old Dec 16, 2022 | 02:31 AM
kawijulian's Avatar
Default 2006 kx 65
my clutch lever is stuck and when i go down to the cable to where it’s connected to, the little bracket is also stuck, i’ve looked up multiple things but still couldn’t find it, the clutch is very hard to pull in and when i hit the bracket back to normal position, i’ll pull the clutch and it’ll get stuck again, i need help with this, thank you.
Old Dec 24, 2022 | 08:20 PM
Sometimes if you place your cable in the cleaning tank, then re-lubing the cable works. Check for any kinks or pinch points.
Truth0928
Oct 25, 2020 01:50 AM
Matt Meserve
Jul 2, 2018 10:33 PM
settik
Jan 29, 2014 05:21 AM
rickslick0119
Jul 13, 2012 06:49 PM
jds636
Apr 22, 2007 08:52 AM
